if my door is 28" wide and i haven't bought a jamb yet to fit-measure so to speak, what width should i leave between the studs on each side, if the jamb sizes are standardized ? or is each one different, in which case it would be a good idea to just go on and buy one before measuring the opening.
As Willie said, 2 1/4" is fine My general rule is that the rough opening is 2" wider then the door. The door frame, is just three legs you cut to size, it's not a preset package for a 28" door. Measure the wall width to make sure you get the correct depth frame.
Ron
