Hi DIYers! I have a framing question.
I am building partition walls in the second story of a rowhome with a "flat" (7-degree slope) roof. Previously there were three rooms upstairs, all with different ceiling heights. The front room had wooden joists that formed a flat ceiling at 9', the hallway had wooden beams suspended from the roof trusses at 8'6" high (perpendicular to the joists in the front room - idk why), and the back bedroom had a drop ceiling covering a sloped ceiling from ~9' high near the hallway wall to just under 8' at the back of the house. I have demo-ed the drop ceiling and want to borrow a little space from each of these rooms to add a small bathroom. However, I'm a little stumped about the best way to frame the bathroom ceiling.
I had thought to build all of the partition walls up to the existing ceiling in each room, then attach joists to the sides of the studs (like balloon framing) parallel to and at the same height as the old hallway ceiling joists. The small, awkwardly shaped space above would then be closed off from the finished space in each room. None of the involved walls are load bearing, and the largest joist span would be 5' 3". Does that seem reasonable? Legal? Any obvious flaws or complications I should keep in mind? Can I use 2x4s for the ceiling joists, or should it be larger boards?
Thanks in advance!
Thanks in advance!
