Hello,
Question with regards on how to know if your wall is straight when framing a wall for finishing a basement. I am doing the stick framing method, laying out bottom plates, and then using plumb bob to transfer the location to the top plates, please no arguments with regards to stick framing, vs building wall on floor and standing it up. I understand how to get it vertically plumb. My question is, what about if the foundation is skewed at an angle along the length of it. If I measure say 6" off the wall at one end, and 6" off the wall at the other, snap a chalk line, and lay my bottom plate off of that line, yes it should be parallel to the foundation wall, but it may not actually be "straight", it could be skewed at an angle, compared to other walls. How do i determine if the wall is straight or not?
I understand how to check for square, using the 3-4-5 rule at the corners, can that be used to help verify a straight or skewed wall?
Thanks,
Steve
Thanks,
Steve
