Hi All,
I'm starting to frame the exterior walls of my basement. I have a poured foundation, and there is Dow rigid foam insulation around the concrete walls (on the interior). It is silver (aluminum foil coated for vapor barrier).
I'm framing a wall along this, and the ceiling joists run parallel to my wall. I can just nail into the joists at the top (I get it), but I had to drop my wall in the middle to make room for a soffit that will house my heat runs.
I would normally block nail into the concrete foundation, but the rigid foam insulation prevents this. How can I secure this lowered portion of my framing to the wall?
Any advice would be much appreciated!
