I'm planning to finish a room in the basement however on 2 of the walls, there is a drain pipe about 4ft from the floor. In order to maximize the square footage of the room, I'd like to put the frame up below and above the drain pipe. Then cover with sheet rock. The bottom frame will be easy as I can use tapcons and anchor to the floor. But for the top frame, how can I install it safely?
