What should the clearence be between framing and duct work?
I'm in Ontario Canada.
I have not been too worried about clearence other then not being close enough to cause noise issues.
The main square duct is hung pretty close to the floor joist, but I noticed that as it gets close to the furnace it gets further away.
It comes in horizontally into the part coming out of the top of the furnace.
This may just be the way it is and not done for a reason.
I have read that you can build walls right up against furnaces except for one side for access.
I do plan on building very close to the one side of the furnace and it is the cold side so I should be fine.
I got googling and found this:
http://www.buildingcode.online/863.html
Which confused me. What is the plenum? The part coming straight out the top of the furnace? It then makes a right turn and runs across the floor joists.
