1 - 2 of 2 Posts
Hi,
I'm building a bedroom addition to an old cabin.
Got a deal on a nice 5' x 6' high window with 5 panes: 2 inward opening ones on either side of a large top to bottom one and 2 smaller ones above the opening ones.
It will go in an 8' wall.
It has no frame.
1. How high should I put the window?
2. Any special framing considerations?
Thanks
Registered User
Two means of egress is required for a bedroom. (Emergency escape) One is the door to the house, other exterior door or window.
The window has to be: 1. 44" maximum above finished floor;
2. 5.7square feet minimum clear opening;
3. Minimum 20" width & minimum 24" height (clear opening);
4. No windows closer than 3' to power line;
5. Req'd glazed openings must open to street, yard or court on same lot. Be safe, G
1 - 2 of 2 Posts
