its a pitched, shingled roof shed. looks to be 4/12We need a lot more info, type of shed, roof style. addition on the end or the side ?
i dont have lumber yards available to meYou find longer than 8' lumber at lumber yards, not box stores.
i appreciate it. ill check this outThis may help to give you an idea.
https://www.familyhandyman.com/gard...hop-illustrations-details-and-materials-list/
Click on the links to give you the prints, etc..
https://www.homedepot.com/p/2-in-x-...Whitewood-Dimensional-Lumber-161675/100024444i dont have lumber yards available to me
gotta hope to get lucky with straight pieces from box stores 😔
How is it siting on the ground with a wood floor of concrete?its a pitched, shingled roof shed. looks to be 4/12
10x8x an odd height.
i would like to add on to the side of the existing shed
making it wider.
Find an 84 lumber near you.i dont have lumber yards available to me
Lumber yards sell would that may be wet and can twist and warp, when you pick out straights that are dry at the box store you are further ahead.i dont have lumber yards available to me
its sitting on a frame thats on blocks thats on a slab.How is it siting on the ground with a wood floor of concrete?
Is it free standing or leaning on another building.
Can you post a picture? of the outside and the inside where you would like to add to it, to see the framing?
So that slopes down in the back?its sitting on a frame thats on blocks thats on a slab.
this is rhe side im planning on extended once the ****ty metal shed comes down.
no it slopes on the sides. the floor is 3/4 osb on a 2x4 floor frame. the frame sits on solid blocks and the solid blocks sit on a concrete slab the side i plan to add on to has a slope so i would essentially be extending the slope on one side out another 8 ftSo that slopes down in the back?
Is it sitting on blocks? what is the floor like?
There could be a problem with frost or moisture in the difference with one end on the slab and what ever you do for the addition.no it slopes on the sides. the floor is 3/4 osb on a 2x4 floor frame. the frame sits on solid blocks and the solid blocks sit on a concrete slab the side i plan to add on to has a slope so i would essentially be extending the slope on one side out another 8 ft
