We have a 8' by 24' cement patio behind our garage that I would like to cover with some corrugated metal roofing. I need to tie this into my garage roof about 4 feet up. Plan is to put up some 4x4 posts anchored to concrete to support the outer edge. Then a double 2x6 across the 4x4s for the beam. Then 12' long 2x6s roof joists, not sure if spacing will be 2' or a little less. Then some 1x4s perpendicular to them to support the metal panels. Have a few questions.
1. Can I use regular wood since it's all going to be covered or do I have to use treated anywhere? I will use treated 4x4 posts but what about the 2x6 roof joists?
2. What is the best way to tie into the existing asphalt shingle roof? Just carefully peel the shingles back and stick some metal flashing up under the shingles? How to attach it to corrugated metal roof panels since there are humps in it?
3. Are 1x4s what I need to use for purlins? Or something else?
