I have a small cottage and I would like to do a 2' bump out that is 8' wide on the on the gable end. I do not want to put in any footings.
The house is 2X4 construction. I figured I would put in a double 2X8 header to open the space up. I thought I would then put plywood coming out (at a 90 degree angle) from the house on the jack studs. I would then build a platform (made from 2X10) between the 2 pieces of plywood. The platform would extend 24" out from the wall. I would then add in another jack stud between the platform and the header. I would then build the 2x4 walls around the perimeter of the (27.5 X 8') platform.
I was wondering if this framing design works? Or if I should do it differently?
Thanks !
Thanks !
