Those are the only pictures that i have. I do not own the house yet and the inspection took place earlier today. The inspector said that it is efflorescence due to poor water drainage around the perimeter of the foundation...from a blocked french drain or lack of french drain. The house is in original condition bulit in 1962. I really like the house and am hoping that this is not a deal breaker.Can you take a few steps back or zoom out a photo? Looks a cold joint at first glance, or maybe the form blew out along the bottom and they chipped it back. Sometimes the inspector will recommend a second opinion from an engineer. What did the inspector say about it, exactly?
It's a home. The bottom 3-4 inches all around the inside foundation wall(only 2 walls are bare) seems to be flaking. There is no sign of mold or water. What causes this?home or rental ? neither would be a dealbreaker to me,,, don't see any present indication of leaking water,,, IF you need more assurance, call in a pe,,, imn-s-hfo, i wouldn't trust the opinion of ANY ' inspector ' UNLESS he was also a pe specializing in home inspections but that's just me![]()
Water intrusion at the base. It could have happened years ago, it could have happened in the past couple of years. Never trust the word of a Home Inspector, since they are only giving an opinion. If you want to pay extra, call in a engineer to check the foundation. Most likely it is safe, and there is nothing to worry about.It's a home. The bottom 3-4 inches all around the inside foundation wall(only 2 walls are bare) seems to be flaking. There is no sign of mold or water. What causes this?
Thanks
By looking at the pictures, how "severe" does it look? Its my first home and I am trying to keep expenses down. ThanksWater intrusion at the base. It could have happened years ago, it could have happened in the past couple of years. Never trust the word of a Home Inspector, since they are only giving an opinion. If you want to pay extra, call in a engineer to check the foundation. Most likely it is safe, and there is nothing to worry about.
Built in 1962. Its a semi detatched duplex. I live in Montreal, Canada. It is not near a lake or river.So severe that there is no problem You are worrying about nothing. How old is the house, where is it located? Really as long as the foundation is sound, building structure does not show any water or weather damage, electric is safe & sound, hvac is good, I would not worry. If the inspector was recommended by the realtor and you want another opinion on the structure, then you are free to find another inspector that is listed in the ASHA website for your area.
