Hi all, I'm new here! Avid DIYer, but some of the foundation repair stuff is a little over my head. Here's the quick back story...essentially, we've got a 50+ year old home on block wall foundation, which is bulging in the middle...In addition, the previous home owner had a drain system put in around the entire foundation base inside, as well as waterproofing panels on the walls.
I hired an engineer, who designed a repair plan for us, which included 5 steel soldier columns to stabilize the block wall. The instruction after installing these was to grout behind them, to maintain contact with the wall the entire way up. He advised to use non-shrink grout. I double checked with an additional foundation repair expert who again recommended Sakrete non-shrink grout.
Here is my problem...we're mixing the grout per directions, but it is WAYYY too runny...we've tried to mix it dryer, and it's just not right. The only way we've been able to get it to stay behind the columns is to let it set up for a while, but at that point, we're racing against the clock before it's not viable anymore....does anyone have any other recommendations, suggestions, or tips?!? Should we try another brand other than Sakrete non-shrink grout?
Thanks in advance!!
Lance (hobsiscool)
Thanks in advance!!
Lance (hobsiscool)
