When I bought my house 2.5 years ago the inspector saw the vertical crack almost on the middle of the foundation on the back of my house. He said it looked like normal set telling and did not act concerned about it. Well, the other day an inspector came out to inspect so e footings for a deck I'm building and he pointed out the same crack. He told me to dig to the footing around the crack and check it out. I haven't done that yet but I did go under the house where the crack is and the blocks are cracked in half all the way through. I called a contractor and he said it was a very common problem in the area and was a pretty simple fix. No blocks need to be replaced but patched up. That's one good thing. What would you guys do in this situation? I have the recommendation from the contractor but I want to see what you guys say bfirst to see if it matches up.
