This one has me stumped. I have been chasing it for about a month now. Any suggestions on what I should check/test next?
2004 Ford Ranger 3.0 V6 Vin Code: U
285k miles
Truck starts fine when cold. Runs great while being driven. Does not want to start after
warmed up and being driven. Has a noticeable miss at idle.
Example: Truck sits overnight, first startup is fine, once warmed up a slight miss at idle. Drive to destination and shut truck off, come back 20mins later, and it just wants to turn over, eventually starting after multiple attempts.
CEL codes:
P0175: Rich on bank 2
P0300: Random/multiple misfire detected
P0316: Misfire on startup at first 1000 revs
Most recently: P0304: Misfire cyl #4 (confirmed a dead spark plug. Still have same starting problem.)
Fuel pressure is good.
Has good spark at coil, wire, and plug
Compression is good on all cyls
Cannot find any vacuum leaks
Since problem started, have replaced due to the problem or routine maintenance:
Both upstream 02 sensors
PCV valve
MAF
Temperature coolant sensor
coil, plugs, wires
#4 fuel injector
crank sensor
cam sensor
fuel filter
air filter
Fuel pump relay
Intake manifold plenum gaskets
285k miles
CEL codes:
PCV valve
MAF
coil, plugs, wires
#4 fuel injector
crank sensor
cam sensor
fuel filter
air filter
Fuel pump relay
