Does anyone have any knowledge on 1970s Ford 3000?
Year: 1974 (I believe)
Engine: 3 cyl gas
Issue 1: Runs hot, but hasn't run hot long enough to cause damage. No sign of blown head gasket. Coolant isn't perfectly clean, but doesn't show oil. No signs of oil on dipstick. The radiator fins are free of debris and the fan runs as it should.
Issue 2: I'm running a 6' bush hog and the deck slowly falls while mowing. Sometimes it will even raise up then fall again. I'm thinking I have a failing seal somewhere. I'm new to running "larger" tractors so I don't want to tear into it without some advice, especially since we're in full mowing swing.
Thanks!
Engine: 3 cyl gas
Thanks!
