I bought a house that had a 2 1/2 car heated garage. It was used as a shop by the prior owner. He was a boat mechanic. It's well insulated.
I use the garage as a shop too. I'd like to keep the temperatures around 45F during the winter, and crank it up to 65F when I'm working out there.
The existing heater was an old 80% efficient forced air gas furnace. It looks like the prior owner rigged it up himself. It vented through the roof. There was no ductwork to speak of. The plenum simply blew hot air into the garage. There was no place for a filter. It was a rust bucket that had seen better days. I've already ripped it out and scrapped it. It seemed pretty sketchy.
I'd like to replace it. I found a 96% efficient 40K BTU forced air furnace that should fit the bill. I will run PVC to vent it right through the garage wall.
My question concerns the plenum. I can't find anything pre-made, and I don't have much experience working with sheet metal. Can I use fiberglass duct board to build a plenum? I've seen kits online, but I've also seen some posts indicating that it is a fire hazard.
If I can use it, how do I attach it to the furnace? I'm assuming sheet metal screws with washers followed by metal tape.
What is the general consensus?
