I live in a hot and humid climate in an old, old house. Right now I have probably close to R-40 in the attic with kraft paper facing down to the living area.
Unfortunately, I'm realizing that the this hasn't created much of an air barrier, especially considering that the house is balloon framed and has numerous cavities over closets etc. Most of the walls are plaster and lath. All of the ceilings were replaced with sheetrock. On the interior, I've been caulking and foaming all the cracks and openings I can find (around vents, pipes, doors, windows, along top of picture molding etc.)
What I'd like to do now is use foamboard (foamular or something like it) in the attic. I'm thinking that I could pull back the fiberglass, cut the foam to fit the joist cavity, caulk or foam it to seal it, then put the fiberglass back on top.
Does this sound reasonable? Would it meet code? I've read that for interior installation it has to be covered with plywood or sheetrock. Would that apply in the attic?
I can't afford spray foam and I think while it may take many weekends to accomplish, this I could do myself. Any info would be appreciated!
Thanks
Thanks
