I have a post Katrina modular home on a slab. It's over built and has solid foam insulation between the walls. I think they must of run the wire to the panel before putting the foam to it. My problem is: Whats the best method of getting a 10-3 UF through the foam to the panel. The panel is 14 inches wide (between studs) and all the romex and main power is coming into the top. There are spare knockouts on top but the holes coming in are full of wire. Has any body had this problem before? Help...suggestions.:(
Joe, what you have basically is a SIP (structural insulated panel) wall. Do a google search on how to wire SIP's and you will find good tips on how to run wire inside of this type of wall. Good Luck.
