Yes, steel is considerably stronger. EMT is stronger yet and considerably cheaper if you can do it.
That's what I would have guessed, but then a lot of the strength is in the shape of the construction.Yes, steel is considerably stronger.
Since you mention that, here's the situation. This will be running through the attic where clearance is about 3 feet (4 ft max at peak), so there isn't really room to bend conduit up there. I can bend in the garage and bring pieces up if I can do it right without a lot of trial-and-error. If I have to make adjustments then it will eat up a lot of time due crawling back and forth. (I've only ever bent conduit in the open where it was easy to check and adjust, so I might be selling myself short here.) I would need to jog toward the truss chord after leaving the box, then angle up, then a 90-degree bend. Nothing too hard, just in an awkward work location.EMT is stronger yet and considerably cheaper if you can do it.
What I do is make the bend on the bench, but leave myself a few inches of excess pipe, then test-fit, mark and cut it right there.I can bend in the garage and bring pieces up if I can do it right without a lot of trial-and-error. If I have to make adjustments then it will eat up a lot of time due crawling back and forth.
I suspect you might. In my limited dealings with flex, when you want the wire to move, the flex moves instead. So you end up having to push/pull so hard that you put the flex at its absolute limit of motion (i.e. kinked as far as the straps will allow) ... and now the bends are tight. Also it's ribbed for your displeasure.Perhaps I'm being overly optimistic about the task of pulling through flex. Am I trading easy of raceway installation for a miserable time pulling the cable?
