1 - 9 of 9 Posts
I should just install a surface mount outlet i know, but whats the fun in that?
My problem is i have a 4 inch metal box 2 inch deep, 30 amp dryer outlet, a mudring to make it flush with the wall. what do i use as a cover plate? lowes has the metal cover but the box would have to be flush with the wall without the mudring, so i would have to drill holes in the box for the screws to bring it out even. they dont have plastic cover plates like regular outlets, im totally lost. i can wire the hell out of an outlet but i cant figure out the cover. does it even need to be covered? nothing is exposed if the outlet is screwed to the mudring. can i use a plastic box and use the same mudring and outlet? i put 2 pics here to show what i have.
Super Moderator
Mount the box, install the mudring, sheetrock, add receptacle, then add cover.
The cove you have will not work.
OH yea, add wire before the mudring!
Reactions: bryan1282
If you are rewiring this then you have the wrong outlet. You should have a new 4 wire outlet and 10/3 with ground. The outlet in the picture is for older work two wire with ground. If you are doing this new and are going to install drywall after you mount the box then you should use a different plaster ring. The one in the picture is a flush mount. Also the 4x4 inch square box is correct but I would use a 2 and 1/8th inch deep box. Mount the box to the stud and then use a plaster ring the thickness of the drywall usually 1/2 or 5/8th inches. I would use a metal cover plate although they do sell the plastic ones.
Super Moderator
The cover shown is for a surface mounted box. It will work with the receptacle, but you do not use a plaster ring behind the receptacle.
You can get a flush mount cover. Look near the covers for the switches and receptacles.
You talking to me?
a cover plate, or trim plate or wall plate if you prefer. (all referring to the same thing)
Lowe's may not but they are available. Actually, I would be surprised to hear that Lowe's didn't really have one and it wasn't simply overlooked.
I'll be darned if I can find a pic of one though but trust me, they are out there. I've put many on myself.
Discussion Starter · #6 · (Edited)
good call on the 4 wire outlet, i checked the instructions for the dryer and it said that should be used after 1996 when remodeling, no problem to exchange that. i had the 10/3 wire already and a 30 amp breaker, i was going by what i already had it was old obviously. the box is 2 1/8 inch deep. ill check the mudrings to at lowes. i found the covers online if i need it and now i see about the 4 wire outlet. thanks guys for the info and help. much appreciated.
lowes and home depot can be retarded sometimes, i have to buy 1 thing at 1 store and another thing at another lowes. ill check the neighborhood hardware store, they have things lowes doesnt have.
Discussion Starter · #8 ·
one more thing, i have a GE panel and it has a Bryant 30 Amp breaker for the dryer, i bought a GE breaker because i heard that you should keep the breakers the same manufacturer as the panel, is this correct?
Super Moderator
If at all possible, yes.
Some breakers are listed to fit in other panels, but if you have the right one, that is the choice to make.
1 - 9 of 9 Posts
