1 - 7 of 7 Posts
Installing a drywall ceiling at bottom of cellar stairs. I have a box for the light and one for the smoke detector to deal with. Used a scrap of drywall to get it flush but as I nailed it to the joist the side not against the joist keeps pulling downward and now extends below the ceiling. Any other tips? Driving me F’n crazy! Thanks
· Super Moderator
Flex the box upward against the nails and or slip a shim near the joist to flush the box.
Assuming that you used a plastic box, use your vibrating palm sander and sand the box flush with the ceiling surface. Take about 2 minutes.
Your oscillating multi tool with plunge cutting blade would be faster.
i screw a small piece of wood to the outside of the box on the side that is dropping,
the wood rests on top of the drywall to support that side of the box,
mount the wood first, then put the box up there and mount it to the stud,
use self tapping screws from the INSIDE of the box to the outside to fasten the wood
1 - 7 of 7 Posts
