Sounds like a fluke voltage (sorry couldn't resist). Probably induced phantom voltage. Connect a 60 watt light bulb across the measurement point and see if the voltage goes away.
I second the votes for phantom voltage on a dead receptacle or a broken/loose test lead. If not that, then a low battery in the meter - although Flukes don't usually have a problem with false readings on low battery.
I go through a set of leads about once a year.....
I buy the real Fluke leads...typically off Amazon. They are made with a much softer rubber and are easier to use. The ones I like have removable tips....lets me swap in the alligator tips....sort of like having a third hand.
Also....if you have the yellow protective 'glove' for the meter, see if you can get the magnet.....they make a strap that hooks into the back of the case and it has a magnet on the end....strong enough to hold the meter when stuck to the top of a Hoffman box. Love that magnet...
1 - 9 of 9 Posts
