I have a fluidmaster 400A, and there's a leak started where the water inlet pipe connects to the threaded shank of the fluidmaster unit.
I took out the old fixed steel pipe running from the toilet tap into the shank, and replaced it with a new, braided steel flexible pipe with the built in cone washers.
After connecting the coupling nut of the braided pipe to the fluidmaster shank, being careful not to overtighten, it still leaks badly when i turn the tap back on. I tried tightening the coupling nut to the shank more, but it gets to the stage where any more tightening make the shank turn, throwing the float cup out of alignment in the cistern tank. I even tried using teflon tape on the thread of the shank before re-tightening.
It's still leaking. To be sure it's the coupling nut/shank connection, I turned the tap off, and filled the cistern with a bucket, no leaks. So it's not the shank washer inside the toilet that's leaking. The leak only happens when i turn the water back on.
I'm using terminology from this manual by the way: http://www.fluidmaster.com/downloadable/download/sample/sample_id/248/
Any ideas?
Any ideas?
