I just installed a an entire fluidmaster toilet repair kit, model 400, in my toilet. It continues to run after the flushing stops.The float is brand new and appears to be settled down completely After flushing the toilet again, the water fills and stops running for around 45 minutes or so and then will run for 10 seconds or so and then stops. If I flush the toilet again, the water runs out of the tank, almost completely, and then won't fill up. The only way that I get the water to refill in the tank, is to push the float down manually a little ways and then the water begins to fill back up. The kit has an adjustment rod that can be turned clockwise or counterclockwise to adjust the float up or down. I have down this both ways with no success.
Help, what else can i try? Thanks!
