Is there any further adjustment of Fluidmaster 400A? I bought one and its to sensitive. The slightest movement of the bowl (sitting down) will actuate the valve for less than one second.
Also does it occasionally by itself. Real fast and quick.
The hose has been trimmed short so it does not go below the water line.
The water level is low as I have a low flow tank. 1.8 Gallons. The valve is as far down as it can go so the lid will not hit it.
The flapper has not been replaced. But I did remove it, check it good and cleaned it.
I have read all of Fluidmasters instructions and have done everything accept use the the little hose holder. My fill tube has its own little holder located inside the tube.
Any suggestions.
Any suggestions.
