Thanks! Not worth it to replace the ballast.Unless you have 277 available, you'll need to change the ballast to 120 volt for them to work.
In a 3 phase 480 volt set up, each phase to ground is nominal 277 volts.
Won't argue with that.Thanks! Not worth it to replace the ballast.
Gary
We had done exactly that and it seemed to work no sparkage or melting!If you do not have 277 volts available, trash them or try to sell/give them to someone who has 277 volts.
Ps....try one on 240 and see if they work.
:laughing:Do the right thing and turn you buddy in for stealing these from a commercial job.
