Greetings!
Wondering if some users could shed some light on a couple of questions......
Background
Our house is a typical ranch style house with a full basement. The house was built in 1998 and we purchased it from the original owner in 2010. 3 years ago we added an addition off the back of the house, and of course it kind of snowballed into more!
We are now working on the main part of the house as we are going to move the kitchen to a different area and also install hardwood floors. Due to the hardwood floors, we are replacing all of the sub floor with 3/4" plywood.
Now that the carpet and ceramic tile is all removed and the sub floor is cut loose, I just now noticed that the floors slope to the center of the house (towards the center beam). I don't know how i missed this, but i did!!
The slope is approx. 3/4" over 12 ft. The slope is pretty equal on both sides.
Wondering if this is serious, did the house settle, or was it built like that? We have absolutely no cracks in any drywall, the ceramic tile was not cracked and none of the doors show any signs of the house settling...no binding, reveals all good, etc. What's kind of weird is that all of the exterior walls are nice and plumb, but the 2 interior walls in the middle of the house, which are close to the center beam are out of plumb quite a bit. Doesn't really make sense. If the house settled over time, the doors should definitely show signs of the settling.
I have talked with 2 architects and a structural engineer and all of them figure that either the house settled during construction (lots of clay here)or it was built this way. All felt that if it was serious, we would have cracks, doors off/binding, etc. As a note, none have visited the house
The floor joists are 2x10's 16" o.c and run to a main/center supports beam that is a triple 2x10. The center beam is supported underneath with steel adjustable posts along with some wood support posts, depending on location of the posts.
In order to fix the floors and/or center beam, I know i COULD jack everything up from the basement, but it is entirely finished. I can see drywall cracking all over (basement)and maybe walls even lifting(?).
Also, we are looking at moving our kitchen which would be over part of the area with the sloped floor. How much is this going to affect the floor/load?
Would stiffening the floor joists help?
I have added some drawings to help........
My questions are:
1. Moving the kitchen - Can I stiffen the 2 x 10's with either a 2 x 6 or micro lam? Glue and screw? How about blocking the ends on the sill plate and center beam.......help at all? I cannot go back in with 2 x 10's due to wiring running through the floor joists.
2. Center beam - is it strong enough? My other concern is that in the basement, there is a span of 13 feet between posts/columns. This shown with the Orange squares in the drawing. Is this span o.k.? I cannot seem to find much on this, just span tables for joists.
Should I add a post in the center of the 13 foot span? Replace the wood supports with steel posts?
Any feedback would be greatly appreciated!!
Background
My questions are:
