So..... I am remodeling a 1971 home. The basement has 9x9s in the laundry and bathroom, then carpet which the original owner said has always been carpet.
My plan was to floor over the tiles (assuming it might have asbestos), and take that carpet up and put the same LVP over all of it. I discovered last week when pulling up the carpet that they likely used black mastic to glue the carpet padding down. I had to scrape a lot of the padding off since it was stick so well. I sprayed it a decent amount with water and didn’t intentionally scrape at the mastic.
It’s my understanding that mastic is non-friable, but I’ve read that you should seal it or skim-coat over it. I ended up just laying 6mil plastic down and installing the floating floor.
It looks great. Is this an issue as far as the mastic is concerned ? Hopefully we didn’t disturb asbestos since we didn’t scrape it up (but we did scrape the padding up on top and walk on it). I’m not sure why they recommend sealing it if you’re flooring over it. The recommended products aren’t readily available at big box stores and I had to get it done.
