I am installing a bonus room over my non temp controlled garage. The garage ceiling is concrete. The area above the garage originally was a screened in porch. i have 7" from slab surface to my existing main structure floor. i planned on starting by building a 2x4 sill plate and continuing with walls as usual. i was then going to vertically fasten a 2x6 against interior studs basically forming a rim joist and then continuing joist as usual. double stacking 2" foam board between joists. after 3/4" subfloor and carpet i should meet existing floor darn near close enough with carpet being installed. My big question here is i know i need a vapor barrier. when and how should i install it? im doing a usual sill foam sealer pad. should i just lay 6mil plastic over the whole slab and build on top of that? If so, should i run the plastic all the way to the edge of the slab? sill foam on top of that? then i was thinking i really like dmx. could i put that down before i even start the rim joist against the walls and have the whole flooring system over top of that?
thank you all for the help in advance. next nice day im starting this so im ready for discussion haha:biggrin2:
