1 - 12 of 12 Posts
Hi All:
Just wondering what the pros here suggest for flooring options in a downstairs bonus room, which is adjacent to the garage. The challenge I have is that the room is also where the washer/dryer are located but it's large enough to be a play room for our one year old daughter. My initial thought was to lay tile on the portion of the room where the washer/dryer is and then just carpet the rest but I'm not so sure I like the look. I don't reallllllly like the idea of an engineered hardwood but that though crossed my mind too. Any suggestions? The subfloor is the concrete slab. Thanks!
Retired Moderator
Ceramic tile is the natural choice ---not damaged by water--can take dirt and grit--
Add a nice thick rug for your young one----done----
Discussion Starter · #10 ·
Thanks for the recommendations everyone. After doing some further research, I think it makes the most sense for us to install tile. I had a chance to pull up the old carpet yesterday and noticed two things: 1) old vinyl tile and 2) that, at least around the perimeter of the room, there is some moisture seepage. The house was built in the 50s and so there is no drainage system around the house (something I will address down the line at some point).
Whatever the case, I was hoping to get some advice/tips on how to prepare the floor. Of course, I will remove the tile and try and clean as much of the adhesive off as possible. The floor is slightly of level and though I will try and level it out a bit with the thin set, I think its something I am okay living with since it’s the basement. I have read varying opinions about how to prepare the floor, i.e. cement board, plastic vapor barrier etc. What do you all suggest? Since this will be a playroom, I would like to keep the room/flooring as warm as possible but I know my options are limited, as this IS ceramic tile flooring and it IS the basement but I would like to limit it as much as possible.
Thanks in advance!
Discussion Starter · #12 ·
rusty baker said:
I guess you realize that it's possible that the old vinyl tile and adhesive contain asbestos. You haven't said how old it is. VAT was common until the 90's.
http://www.asbestoshistory.net/asbestos-tile.html
Yes. I'm having a company come check it out and if it's asbestos containing, well have it removed accordingly.
1 - 12 of 12 Posts
