Hi
I have a big mess on my hands - hope someone here can help.
This is an old 1930's house, but the room I refer to must have been done more recently...maybe the 60's...?
I have what must have been a carport or garage at one point. The original owners enclosed it and put down some sort of leveling compound on top of the original concrete. I'm not sure what this is, but it's a red brick color and about 3/16" thick. On top of that they laid some sort of sheet vinyl / linoleum. Again - not sure.
I have an extremely tight budget and wood floors in the rest of the house so I thought that slate tiles would be a great way to go in this room...also have a wood burner in there so that would cover the need for a hearth as well.
I have tried to get the sheet flooring up and it's a nightmare. The top 'printed' layer has been removed but the backing and/or adhesive will not budge. Right now what I have is 1) the original slab exposed only where the original seems were - the leveling compound has chipped off in those areas. 2) some clean leveling compound and 3) the backing and or adhesive of the sheet flooring that will NOT come up. It's stuck super tight. I've tried scoring and soaking it and I can get some of it up with a sharp putty knife but it's super labor intensive.
The "contractor" helping me insists that I can just tile over all of it ...all three levels if it...by just using a thick layer of thinset with latex. I'm afraid that will not adhere to the vinyl and I also know that the slate is pretty fragile and might crack if it's set on an uneven floor. Am I nuts, or is he?
Not sure what to do. Do I get on my hands and knees with my knife and try to remove it all? I'd really rather not. Or is there a floor leveling product that will cover all three substrates and that I can also tile over? Also have thought about putting down durock, but he says that would be worse.
Sorry for such a long post - just want to describe it well. I'll try to post a picture if I can figure out how to.
I sure could use a budget friendly solution that I could do myself. HELP IS APPRECIATED!!! Thanks!
