Hi,
I was doing an attic inspection today and noticed that a part of the freshly blown in insulation was sagging. After further research I saw that the board that were somehow installed under the joists are broken. The sheetrock ceiling so far thankfully has not been damaged.
The last picture is from the garage. I suspect the same kind of boards to be installed over the sheetrock ceiling and under the joists.
I am thinking that the boards got installed when the house was built (1974) and before the sheetrock ceilings in the rooms were installed.
I am afraid that over time the sheetrock ceiling will give in or that more and more insulation gets sucked/blown into the space between the boards and the sheetrock.
I need suggestions on how to close the space since I cannot access the area from the bottom (I don't want to take out the sheetrock ceiling).
Thank you!!!
Thank you!!!
