Since you had a foot of water in your basement, that indicates that the groundwater was a foot higher than the elevation of the basement. Plugging the floor drain will do no good, the water will simply come up through cracks in the basement slab. If by some miracle there are no cracks in the slab, the entire slab is likely to break due to the water pressure.
This is an unfortunate problem that is not easy to solve. The best solution is a perimeter drain (there are many threads on this forum related to perimeter drains, sometimes called French drains), just do a search and see all the comments. Perimeter drains can be outside the slab footprint (an external drain) or inside the walls (an interior drain). In all cases, the water needs to flow to a lower elevation, which could be a storm drain if your town allows that kind of connection, or a stream or possibly a low spot on your lot. You are going to need to do an accurate elevation survey of your property to figure out where you can drain to, and remember water flows based on the relative elevation of the water, not the ground, so a low spot may not work if it fills with water during a flood event.
Start by doing a survey, then talk to the town about the storm drain. Installing a perimeter drain can be hard work, and you may want to consider having a contract do the work.
