Hello!
So, there I was... renovating the kids' bathroom. With about 5 tile left to lay I happen to notice a slight drip from the sink shut off valve. Rather than shutting off the water supply before tinkering with the plumbing, I tapped it with my finger. The shut off valve fell off and began to drench my tile installation. Let's not get in to why that happened. :wink2: The water was shut off within 60 seconds, but that didn't stop everything from being drenched.
I was noticing the tile would discolor when I'd cut it because water running across the back. It seemed as though the water would seep into the tile. Anyway, I stuck those pieces in the oven for a bit and they dried out and the color returned. That was before the flood.
I'm not as concerned about the quick-set. Despite freaking out and all the wet/dry vac work, I managed to not apply much pressure to many of the tiles. My main concern is the discoloration of these tiles. Clearly I can't pop them in to the oven to dry them. I've got box fans focused on them now.
If it's relevant, I am installing the tile on Ditra and had been laying tile for about 4 hours at the time of the flood.
Surely this has happened to someone out there. How screwed am I?
Thanks.
Thanks.
