Hi All,
I'm looking for a cheap/economical fix for a problem that causes my basement to continually flood. The outside door to my basement obviously sits below ground level and there is a sloping sidewalk down to the door. The sidewalk ends at a landing which houses a small french drain (about 12" x 12"). The problem is when it rains really hard, water rushes down the walk and off the roof, builds up in no time on the landing and overtakes the french drain within minutes. Eventually, water starts coming in the door.....really coming in the door, not just trickling. To remedy this, I've made sure the door is nice and tight and I've also introduced a small sump pump that I've slipped into the french drain. It works okay, provided it can keep up with the amount of water coming down but it isn't perfect. There have been several times we've lost electricity during storms and of course, my little system won't work at all and the basement starts to flood again. I can't imagine how this passed a home inspection! Anyway, I would be really grateful for some suggestions on the subject.....thanks for your time.
