We removed a stud wall and were suprised that it did not sit on a massive concrete floor. Instead the floor is 2 - one for each room (as it was) now a single room but 2 floors separated by a piece of wood.
I'm worried about expansion - also the level needs some slight work I think. I will bash down the edges and check for level. If it is level can I ignore this 8 inch wide channel filled with wood, just laminate across it as I am looking to make a single floor.
If it isn't fully level will a self leveling compound fill over everything and be able to change the differing expansion rate of the wood and the concrete.
Thanks :no:
Thanks :no:
