I'm trying to install a floating wood floor in my condo:
The HOA rules state: "For wood floors adequete sound proofing must be installed". A minimum of 3/8" plywood or cork underlayment must be used with a minimum of 1/8" mastic on either side of the plywood."
The idiots at the property management firm don't know how to interpret this language and keep giving me the run around and changing requirements. I talked to home depot and my contractor. They said I should install a 1/2" plywood sub-floor and on top of this lay 1/4" of cork sound proofing. On top of the cork i lay my floating wood floor (about 1" thick). They said this should exceed the requirements. Is that correct? Any advice or knowledge of the best and most cost effective way to meet this requirement?
