I am looking to build something similar for a friend of mine.
knucklez....for those that dont have experience in the building trades, drawing a plan for a deck can be difficult. Almost any good deck building book from Hombre Depot should have at least a couple good plans for free standing decks. You just have to adapt it to your specific application.thx. that was exactly how i plan on building the deck, except i never thought about the diagonal bracing. i think this is a good idea to help compensate for the lack of house connection.
my research into deck building has led me to this conclusion: a deck needs a detailed plan, to the point where it should take you longer to create your deck plan than it does to actually construct the deck.
am i wrong? :thumbsup:
Knucklez
I sure hope not.thx. that was exactly how i plan on building the deck, except i never thought about the diagonal bracing. i think this is a good idea to help compensate for the lack of house connection.
Knucklez
Even on a deck not attached to the house?i live in cold climate and local building code requires 4' deep post holes.
Knucklez
I can say that I helped some good friends build a backyard deck using Dek-Bloks (Ft Worth, TX). I found that using a free 2-D CAD program (QCAD) helped me immensely. I think that the time taken to carefully (CAREFULLY) design and draw a structure will reveal possible design flaws and gotchas that may not appear, even on a hand-drawn design.my research into deck building has led me to this conclusion: a deck needs a detailed plan, to the point where it should take you longer to create your deck plan than it does to actually construct the deck.
Knucklez
