1 - 16 of 16 Posts
Hi all..I have a thermal image of my electrical panel. As you can see a few of my breakers are "warm". The two at the top are GFI breakers for the kitchen. The upper right breaker tends to trip every so often..would this be due to a bad breaker?connection?
Also, you can see the electric water heater breaker (mid right side) which is also "warm", as well as the wire (which you can see coming out of the top of panel). Now none of these are warm at all to the touch, but it seems to me that I have some issues.
Any suggestions?
Thanks!
· Electrical Contractor
Whatever breaker that is I would turn it off and check that circuit out. Or have a qualified electrician check it out for you. If you have an amp meter it would be nice to check how much that circuit is drawing.
What Missouri said. If the user has the thing on a 17.4C scale then that image is VERY misleading.
My bad now I notice what range the scale was set at. That is not too bad. I know our tankless water heater breakers get warm too.
1 - 16 of 16 Posts
