Hi there,
Various lights in my house started flickering last night. All the lights are on one circuit.
I went down to the electric panel and when multiple lights on this circuit were on I could hear a sporadic "buzzing" sound. Researching causes online lead me to believe that the cause is either a bad breaker or a loose connection at the breaker that simply has to be tightened.
The question is, how can I tell which it is?
I'm not a fan of doing any electrical work at the panel but if I simply need to tighten a screw I don't want to pay an electrician $150 to ring my doorbell and tighten a screw. If I do it myself, is it simply a matter of turning off the main breaker, removing the panel cover, and tightening the screw on the breaker? Do I need to use a voltage detector or am I fine once I turn off the main breaker?
Any help would be appreciated.
Thanks.
Thanks.
