In my garage I have 4 light sockets. The light switch has motion detection so when I enter the garage the lights turn on automatically. They turn off after about 5 minutes of inactivity. I initially tried 4 LED lights, but the lights would not turn off after the 5 minutes of inactivity. They would go to a dim lighting state. I put in one incandescent light into one of the light sockets and that solved the problem. After the 5 minutes the lights went off.
I have 3 basement light sockets that are on the same circuit. Recently one light started to flicker, then it went to a low light state (see photo). I replaced the existing 600luman bulb with the 750luman bulb. The lights are staying on for now.
Is the 600luman bulb just ending its life and that is why it flickered and then went to the dim state? I had the same problem in the garage a few months ago maybe with the same type of bulb. Are the two bulbs that much different to cause a problem with the circuit? 135ma vs 138ma. I would like to use 5000k bulbs but the one’s that seem to be working are 3000k. I am not sure if that would cause an issue.
