1 - 20 of 39 Posts
MORNING
HAVE ANY OF MY FELLOW DIYERS USED THE FLEXFIRE LED SYSTEM?
I HAVE A FEW QUESTIONS ABOUT THE CONNECTORS.
THANKS
JEFF
Naildriver
Good Morning
RE: under cab LED strip lights, L shape kitchen.
I want to use 24volt 3000K FlexFire LED strips usinga Zurich 24V 200W Elec Dimmable driver. There will be 2 runs of 16 feet in the L-shaped kitchen.
I have a few questions about making connections and the driver.
1. A. Will their GRIP SC C3 10 0 solderless connectors fit inside their GEM CH A CVR F 1M channel and diffuser so I don’t have to use wire nut connects outside of the channel?
B. Can this connector be used to connect 16g to 16g?
connect LED strip to LED strip?
connect 16 g to LED strip?
As you can see in the top 2 images, they appear to have 2 different types of connectors, both solderless or non solderless.
*I have never soldered
2. Can their SC CNR 10 5 corner connector be used for 2 adjacent LED strips at a 90 angled
3. Will a 24 V 200W dimmable driver be sufficient for 2 runs of 16 feet each and no voltage drop.
The driver will be in the center, in the cabinet above refer.
*I HAVE TO NOTE THAT FIREFLEX TECH HAS BEEN VERY HELPFUL IN SUGGESTING AND ANSWERING QUESTIONS. HOWEVER, THEY ARE CLOSED TODAY AND I'M TRYING TO GET SOME ANSWERS.
Thank you,
Jeff
Automotive lighting Rectangle Bumper Automotive exterior Auto part
Rectangle Font Parallel Engineering Screenshot
Automotive tire Automotive lighting Automotive design Automotive exterior Vehicle
Cabinetry Countertop Property Window Kitchen appliance
Cabinetry Door Picture frame Interior design Wood
I've used Flexfire LED strips, but not the specific ones you are referencing. Looking at the specs for the connectors and Gemini channels, it looks like they should fit. If you really want to be sure, wait until Monday and call Flexfire.
The solderless connectors you mentioned are spec'd for 20-22 AWG wire, so you can't use them with 16 AWG,
If the wire length from the driver to the LED strips is short, such as from the top of the cabinets to the bottom, you can use a smaller wire gauge.
The connector in the bottom photo is solderless in terms of connecting to the LED strip, but has pigtails that connect to the wiring back to the driver. These are the type I used, since the other type wasn't available at the time I installed my system.
You didn't say which LED strips you are using, so it's not clear how much power you will need to drive them.
Note that the 200W driver is not a Class 2 device, so you will not be able to use Class 2 wiring methods. You'll need to use Class 1 methods, the same as you would with 120V wiring. To make life easier and allow you to use Class 2 methods, you might be better off with a pair of 24V, 96W drivers, one for each 16' section.
Thank you for your reply.
I will be using the UltraBright UB AT1 30K97C 24V 16ft LED Strip Light.
Each run is 16 feet. I was just using the 16 g to help in avoiding voltage drop.
The tech said the items listed would work with each other.
The top photo GRIP SC C3 10 0 solderless connectors are the ones they suggested. I found the others on their website instruction video.
Can you explain a Class 2 device as opposed to a Class1, please?
did some research and found that Class 2 drivers are less than 100 watts and do not need conduit. It seems that there is a gray area, on various forums, whether conduit is needed with Class 1. I try to overbuild and error on the side of caution so I will accept Class 2 as desirable.
Question: If the LED strips are 3.5 watts per foot and I have a total of 30 feet that would equal 105 Watts at full power. If I want all the lights on 1 switch than I will need a Class 1 driver?
Thank you
It isn't quite as simple as 100W. It's really 100VA, but can also be as low as 60VA if you are using 12V drivers. Class 2 requires that a transformer or power supply inherently limit its output to 100VA (or less). This is to keep the current low enough to reduce the risk of fire in case of a short or other failure.
That said, there are some Class 2 drivers that are over 100VA, but achieve this by have multiple outputs, each limited to 100VA. So you would still need to have more than one 24V power feed from the driver to your LED strips. That will also help reduce the current in feed, further reducing voltage drop.
When choosing a power supply or driver, don't confuse a Class 2 rating with IEC Class II. IEC Class II governs the construction and insulation of the power supply and protecting users from the risk of shock, and has nothing to do with limiting the power output.
In addition to a Class 2 driver, you need to use wire/cable that is also rated CL2 or better.
With Class 2 wiring, the rules are more relaxed, allowing you to make splices and connections without them being inside an approved junction box. Wires can be smaller; 18AWG and smaller can be used.
If you go with Class 1, then the rules are as if you were wiring a 120V circuit. Junction boxes required, wires no smaller than 16AWG, properly protected using conduit, or NM-B cables.
Thank you, my education continues.
If 2 drivers, would need another switch but prefer only 1.
Would this multi tap work?
Pliers Font Rectangle Cable Electrical wiring
View attachment 679224 put
In theory, you could connect more than one single output driver to a single dimmer. BUT, there could be some potential problems. One is that for a particular setting of the dimmer, the two drivers might choose slightly different dimming levels (such as 60% on one and 50% on the other), and that could be noticeable. It might require fiddling with the dimmer setting to get them both to the same level.
The other possible problem is inrush current when you first turn on the lights. The drivers have pretty high inrush currents, and two of them kicking in at the same time might exceed the specs of what the dimmer can handle. For example, the Zurik 200W driver has an inrush current of 15A, which should be ok. But two 60W drivers have 28A (14A + 14A) of inrush current, which could blow the dimmer. So for this to work, you would need a dimmer that can handle the much higher current load.
Your photo of the driver doesn't have enough resolution to read the output specs, but from the pigtails, it does appear to have 4 outputs (2 in each cable).
The advantage of using a multi-output driver is that it should set the dimming level on all outputs to the same level.
Zurik does make a 192W multi-output model, similar to the 200W single output model you originally mentioned. That would appear to fit your needs. Still, check with the folks at Flexfire to see if they agree. This driver has an inrush current of 19A, so be sure to choose a dimmer that can handle the load.
Discussion Starter · #9 ·
For example, if say 18 gauge wire used in system and amounts to 30 feet, is that the footage used for the driver maximum plus 10%?
or
Is the total length of the 5 LED strips, say is 13 feet, added to the 18 gauge total of 30 feet?
Which would be 30 + 13 = 43 x 1.1 = 47.3
Does it make difference if the 30 foot run is split into 2 runs and there are 2 runs of 15 feet instead of 1 run if 30 feet?
Just trying to learn-Thanks
What wattage 12 volt dimmable driver would be needed?
Since you will have a driver with two separate outputs, each output must drive separate sets of LED strips, with no connection between them. You can't common the two outputs together.
Calculating voltage drop gets a little complicated in layouts like this because one 4' wire segment carries just the current from say a single LED strip, but then the next upstream segment back to the driver carries current from two or more segments. So you need to calculate the voltage drop for each segment and add those numbers for a each full path back to the driver together to figure the actual voltage drop a strip will see.
The voltage drop along the length of the actual LED strip matters, but as long as the last LED at the far end of the strip gets enough voltage, it will be fine. Since we don't know the gauge of the conductors on the LED strip, we can't easily calculate what the drop would be. So all we can do is worry about providing enough voltage at the connection point to the strip and make sure it is within the manufacturers specs.
Your picture of the wire layout got cropped a bit, and I can't see the length of the strip all the way on the left. But adding up the other lengths, I'm guessing it might be a long one of about 15', since you say you will have 30' of LED strips.
You show one 4' drop feeding two LED strips. It's ok to do it that way, but you will need a splice there under the cabinet to branch out left and right to the two strips. Consider how you want to make the splice and hide it or protect it from damage. Another option would be to make 2 drops, one for each strip, and make the splice up at the top of the cabinets where it will be more out of the way.
One easy way to make the splices is with Dolphin Connectors (aka "B" Connectors). They are pretty compact, and you can splice up to 3 20 gauge wires in one connector. You need to use proper crimping pliers in order to make a solid connection. They are made to connect right through the insulation without stripping, but for beginners, it is often better to strip and twist the wires and then crimp them in the connector. No extra insulation is needed.
Here are two different ways you could lay out the wiring. The longest run on the left, at 22', would have a voltage drop of just under a volt powering a full 15' LED strip using 20 AWG wire. I didn't calculate the voltage drop for the other driver output, but since it is shorter than 18' and doesn't carry the current of all the segments along the entire length, it will be less.
The bottom layout would have the lowest voltage drop, since every segment has its own run back to the driver, and no segment is carrying power for more than one segment. It's probably overkill.
If you want to conceal the wiring within the cabinets, you could use some plastic Wiremold.
Product Rectangle Azure Slope Font
Discussion Starter · #11 · (Edited)
**I sent a better photo
Thanks.
Thanks.
There is approx 30’ of load. The 5 LED strips are approx a total of 14’. I thought by T’ing off on 2 of the LED’s, it would lessen the load by 8’, but maybe that s not necessary.
An electrician friend suggested using a 12V 75W dimmable driver. He also said I could use 14/2 wire. I’d rather use 16g or 18g wire as it would be much easier to hide.
The LED strips that Fireflex recommended use 3.5W per foot.I’m right probably making this harder than need be, but I try to do the best just possible.
Should the total of the LED strips, 14’, be added to the 30’ of load wire?
You are very kind to take this interest.
Thanks.
Ok, I'm confused. Originally you said that there would be 2 runs of 16'. I took that to mean two 16' strips of LEDs. Now you are saying there is approx 30' of load. Is that the total length of the LED strips, or are you including wire lengths in that? Makes a big difference. Although wire has some resistance and that consumes a bit of power, it is usually not considered part of the load.
Discussion Starter · #13 ·
Sorry, I’m confusing the situation.
Yes, I started out with 2, 16’ runs but have changed to the one contiguous run.
Instead of explaining it, maybe look at the non cropped photo I just sent.
The 2nd layout you sent is close to the that photo.
I don't see an updated photo. What is the length of the LED strip all the way on the left side?
Ok, based on the updated diagram, you have 160" or 13.3' of LED strips. At 3.5W per foot, that's a total of 46.7W.
I think you would be fine with a 60W, 24V single output driver.
Here's a diagram similar to yours with voltage drop calculations. I made up some numbers for the various horizontal wire segment lengths based on the photos of your kitchen. Not sure how close to your actual lengths they might be, but it's simple enough to recalculate things.
[Edit: I got side tracked during my original calculations and forgot that you were using a 24V supply. I've corrected the numbers below to reflect this.]
As I said earlier, the worst drop will be at the 44" segment. I estimate the voltage there will be 23.65V. I don't think you will have any problems due to voltage drop with this layout.
If you really want to be sure before installing everything, do a simple bench test and wire up the full 15' reel of LEDs to the driver using a 22' section of 20 AWG cable and power it up. If that works to your satisfaction, this configuration will also work.
Rectangle Font Slope Parallel Pattern
Discussion Starter · #17 ·
Thank you for your time and it would have been less work and frustration for you, if I had just included a layout and dimensions and you could have gone from that without me muddying the waters.
If you were to do this from scratch, how would you do it? Layout, driver specs, etc?
I can install the driver anywhere that would be more efficient, just want to have the safest and most professional installation possible. Originally, I was going to T off in the attic but got approval from the boss to run the wire in the upper cabinets, reducing the length from 4' to 3' on three of the drops. Also, I corrected the distance from drop to drop.
Once again, I can't thank you enough for your expertise, time and patience.
*Photo of your diagram with measurement corrections.
Although it is ok to run the wires in the attic, it's best not to place the driver there. The hot attic temperatures will shorten the life of the electronics.
My first consideration for the layout is driven by what's practical in terms of where to place the driver and how to run the wires. It needs to connect to AC power, so where can it be placed that allows that? If it can be placed somewhere in the middle of the LED strips, then that allows you to run two sets of backbone cables, reducing the length of each - one to the left and one to the right. Even with a single output driver, that will split the load across the two cables and reduce the voltage drop on each one. You've take that approach by having a direct connection to the driver from the rightmost LED strip. A 50/50 split of the load would be nice, but in your case, the load on the backbone is low enough that it still works out.
Sometimes, you may have no choice but to place the driver at one end. Then you are faced with passing the current for all the strips through one backbone cable, which may force you to use a heavier gauge cable. The other choice would be to run multiple cables. In my original pair of drawings, that was what I tried to show with the bottom drawing. You don't necessarily need to run a separate cable for each LED strip. How many strips you can connect to a cable will depend on the length/load of the strip(s) and the voltage drop it creates.
I prefer to use smaller gauge cables if possible. They are easier to conceal, and with 20 AWG, you can use the solderless connectors. I prefer solid wire rather than stranded, as it will keep its shape better when you need to bend it. Just don't bend it in one spot too often!
To calculate the voltage drop, you need to know the wattage and current that each strip requires. At 3.5W per foot, that's 0.292W per inch.
44" strip: 0.292 x 44 = 12.8W
12.8W / 24V = 0.53 A
Do that same set of calculations for each strip.
The next step is to calculate the voltage drop for each wire segment. Start with the segments that feed each strip.
44" strip:
10' of wire x 2 (the current has to travel down and back) = 20'
20 AWG has a resistance of 10.15 Ohms per 1000 feet. So 20' of wire is 0.203 Ohms.
The voltage drop is current x resistance (IxR), so 0.53 x 0.203 = 0.1076V
As you move upstream to the driver, the backbone segments will be carrying current for more than one LED strip, and you need to add the current values for each strip together when calculating the drop for that segment.
Finally, to calculate the total voltage drop that is present at a LED strip, add up all the drops for each segment in the path between the strip and the driver.
For the 44" strip, that's 0.1076 + 0.0853 + 0.1839 = 0.38V. 24 - 0.38 = 23.62V at the strip.
At 23.62V, you're only 1.6% below the nominal 24V requirement, which is a good place to be.
Here's an updated set of calculations based on your wire lengths. Overall, things didn't change much - just a few hundredths of a volt.
Product Rectangle Font Slope Material property
Discussion Starter · #19 ·
44" strip:
Thank you very much!
-All low voltage wires and dimmable driver can easily be installed in the hopper-style cabinets that are above the standard upper cabinets.
-Center the driver.
-2 sets of "backbone" cables to split the load makes a lot of sense.
-Solid 20 g cable will be used.
*With the relocation of the dimmable driver and no measurement or other device changes, where would be the best location for the dimmer driver?
**I like the idea of the 2 backbone ( thanks for that adjective) cables, one running to the left and one running to the right.
***With the above changes, which dimmable driver ( volts and wattage) would you suggest?
I'd prefer to spend more on proven, quality devices and be assured, as much as possible, that no voltage drop can occur or overheat.
I am not obligated to purchase all or some of the products from FireFlex, but I have read a few good reviews on their product and system. Perhaps you might suggest another supplier.
I am 74, retired and live in West End, NC. Worked in the restaurant industry for 21 years and after that, for 26 years, owned and operated a commercial cleaning and property maintenance business, for multi-tenant buildings and trucking companies, in the suburbs of Chicago. So, I am conditioned to long hours, 24/7, and production-type work. Thought I would want to take it easy in retirement, but found that I miss working with my hands and the sense of accomplishment. So, thank you very much for your help, I really do appreciate it.
P.S. I am astounded that you haven't run away from my post with all my jockeying around.
1 - 20 of 39 Posts
