is it ok to connect a 6" flex/semi-rigid and rigid takeoff together? i have some obstacle that require a U-turn (not a tight turn), so i like to hook up some flex to rigid one for the turn. also for connection between the two, do i just foil type together or there are more permanent ways to do it.
update w/pic: the concrete wall on the left is the obstacle which block 3-5 inches of 6" pipe if i use rigid takeoff and elbow. try to figure out the best way move the pipe on right to the left
