The condensor fan and gas flame goes out the moment the blower fan comes on. This results in an Error Code #34-- "Ignition Proving Failure" however it does not stop after 3 trys but is continuous. I have checked the green ground wire and have cleaned the flame sensor.
There is another suspicion I have. This is a Carrier 90+ with a failed secondary heat exchanger (leaking water)- I tried to clean/rod out some of the rust and this problem started immediately after I put it back together. I have checked for corroded connections, tighted every screw, checked all my vacumn hoses, etc.
I know I need a new heat exchanger but I need heat until the new one comes.
Does anyone have an idea of what I can do?
Thanks,
Thanks,
