As the title says, I walked in the door, wife at dining table doing homework with kids and she suddenly asks, what's burning..... I thought maybe just a little smell from portable heater that was running, but then it got way worse. I noticed display on thermostat, so I went to check furnace and shut it off with switch. Then called fire department, which came out and checked. All breakers were good. I had pulled display for thermostat off wall to see why it was dark, they asked me to turn furnace back on, so I put display back on wall, it came on, I kicked thermostat up to 75, was set at 69 and furnace kicked in.
The final thought was fan would kick off, so would thermostat, but flame would stay running and was therefore overheating the furnace.
Any ideas? I've been trying to clean the furnace and look for the obvious, but I'm no tech. I can however spot bad wires, a burnt spot on board, etc and I've pulled and cleaned the squirrel cage before, so I can handle the basics, it's testing I can't do. I plan on calling someone tomorrow, but looking for anything between now and then.
The furnace is a Goodman Model GMP 100-3 and was apparently installed in the mid 90's. The thermostat is a honeywell VisionPro IAQ that I installed in the last 7years or so. All wiring is also new since I bought the house in 2008 as I had that all replaced and no breakers were tripping.
A friend texted me an article about fan not staying on, so I'll read that. I also just googled the Thermostat blank screen and came across a post of mine from 5years ago, seems furnace overheat issue will cause that, but I'll re-read that. Here it is if anyone else wants to read as well....
For now, if anyone has suggestions or ideas, that would be great as it is cold out, I luckily have a hardwired electric baseboard and some very nice electric heaters, so i'll try to keep house warm with those for now. Doubt I get much sleep....
