1 - 8 of 8 Posts
I am planning to replace the exposed galvanized pipe in the basement of an old house. I would connect to the existing supply system for three 1/2" runs behind plaster walls running up to the second floor and for the 3/4" supply line to the house, and replace the rest of the system with CPVC.
Doing a fixture count, the house should require 21.5 fixture units, and the supply travels at least 100 feet from the street to the rest of the system. Table 610.4 suggests a pipe size of at least 1" from the street ("Building supply and branches") is required, rather than the existing 3/4.
It would be a *big* job to replace the supply--driveway, multiple retaining walls and walkways, it probably goes through the garage foundation, etc...
Is there any reason to replace it before we have to? (Does grandfathered undersizing by 2-5 units create any unsafe conditions)?
Is a municipality likely to require us to replace the supply when we get the permit or inspection on the CPVC?
A whole lot faster, easier, and less fittings if you used Pex instead of CPVC.
It also will not crack like CPVC when it freezes.
Reactions: Tom738
Premium Member
I would say not likely. However, I don't know your permit offices way of thinking. Mine wouldn't care on an existing service
Size the home as code suggests- you didn't mention elevation change. You gain or loose pressure due to elevation change too. Hopefully you're not on top a hill....
Reactions: Tom738
Discussion Starter · #6 ·
Thank you for the suggestion. I already picked up the CPVC but don't anticipate it being problematic--I haven't used it before but the runs are fairly straightforward, as is the technique.
It was a close call, but I think the deciding factor between PEX and CPVC was the fact that the PEX fittings are proprietary--whereas if you use CPVC, you are much less likely to have to worry about a company going out of business, whether a particular fitting design turned out to be problematic, or whether you'll be able to find someplace that sells the part you need.
Completely wrong on that assumption, it's been around for at least 5 years that I know of, and any new home I've seen being built in this area uses it.
retired elect/hvac/plumb
Id have it bored from the basement out to a hole by the street ,then have a new tap done on the main.
That would save tearing up the yard/driveway.:wink:
Reactions: Tom738
1 - 8 of 8 Posts
