Repainting a room as part of a remodel. This room is small, about 11' x 12'. The walls are in bad shape-lots of little nicks, dings, bad drips from the previous paint job(not me!). The walls are almost what I would call a texture finish, maybe they used a 3/4" nap, it is very bumply. So, I sanded the walls down with 100 grit(used a random orbit attached to the shop vac, nearly no dust) and am touching up the dings and dents with mud. Problem is, all the touched up spots will be smooth, the rest still has some texture. I want a consistent finish. So, how do I handle all the recently repaired smooth parts? Hit those areas with some primer on a thicker roller first, then do 2 top coats?
Comments are appreciated!
