I have an old bathtub and faucets (1931 house). Both hot and cold handles making loud squeaking/screeching noise when turned on and off. While there is no leaking at all, I've been here since 1994 and no work has been done on these faucets, so the innards at are least that old. I've taken all the outer hardware off; the stem is still attached. In this state, it's still noisy when turned.
I assume I can't just push some plumbers grease in there without removing the stem and hope that stops the noise. I assume I must remove the stem to look at the washer and O-ring. I know to shut off the water to the faucet, then relieve the pressure. There are two nuts (see pic below), with an "outer" nut and an "inner" nut. To remove the stem, do I unscrew the outer nut or the inner one?
Will changing the washer and possibly the O-ring likely stop the noise?
In addition to putting it on the threads, should I put plumbers grease on the washer? And on the O-ring? Should it be a silicone grease or just any plumbers grease?
Thanks for any help.
