Hello everybody,
I am in the middle of rebuilding my shower's floor because leaks damaged the subfloor (engineered wood). Please help me with how I can redo the subfloor without impacting the walls that surround the shower in three directions.
I've removed the floor layers, including most of the damaged subfloor. As you hopefully see in the picture, I see two I joists underneath and one joist (on the left, away from the subfloor hole) that looks like a regular one (not I shaped, not engineered), that go in front to back direction in the pictures. The back wall is external, the one the left borders a room and the one the right borders a hot tub (this wall extends around 3 ft from the external back wall and it covers the hot tub's width; you are pretty much looking at all of it).
I need to replace the subfloor, not sure how much I should cut out on the left and the right.
I would think that the left/right walls are non-load bearing, and they don't need support from the subfloor?
Would it be ok to cut the remaining subfloor up to the edge of the bottom of the walls, and simply put a new board, perhaps with blockers/ledges for support (for the bathroom pan really, not for the walls)?
Thanks in advance.
Thanks in advance.
