I have painted before but for a couple of reasons I screwed up on the cardinal rule of wet-edge and of course got hat-banding. It's a bathroom in my house and is not a great deal of wall space.
Yes, I know it looks like it was done by banana crazed monkey crack. I had to paint at night but can now work during daylight hours.
I'm using high grade Sherwin Williams flat finish red with tinted primer.
I do not want to do the whole job over if I can avoid it. I have one coat of primer with one coat of paint put on. I don't know that the wall streaks are going to be a problem with the second coat. But if I put on the second coat of paint then re-primed the cut-in that banded, blending it gently into the wall coat then repaint that part will it work.
I have used some of this paint and primer from this batch on a table top and it does cover very well. Any help, comments, or thoughts on what you see as other problems would be of great help.
Thanks,
Brian
Thanks,
Brian
